Local Time 17:42 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Switching video
James_From_Canb
Posted: 11:58am 14 Feb 2013
What would be a good component to switch video signals?
I'm finally getting around to fitting reversing cameras. I plan to have a switch in the cabin that will allow me to select between two camera views - one pointing down and one pointing back. The video will be displayed on an LCD VGA screen mounted on the roof. It has two inputs. One will be for the cameras, one for the MM.
Can anyone suggest a good component to switch between the two signals? Preferably inexpensive, easy to set up, and robust. Any thoughts on whether a standard car relay would be suitable?
James
OA47
Posted: 12:29pm 14 Feb 2013
James, one of my vehicles has a screen that is shared by the sat nav, radio, dvd and reversing camera. The switching of the reversing camera video is done by a 12v relay activated by the reversing light cct.
MicroBlocks
Posted: 05:08pm 14 Feb 2013
Why settle for 2-3 if you can get more.
8-input Video switch
James_From_Canb
Posted: 08:12pm 14 Feb 2013
That's a good link. Thanks. I'll try the 12V relay first and build a switch box if the relay gives a dodgy signal. I don't expect to need 8 inputs. Well, not yet.
Then again.... I have 2 rear vision cameras. I could add 2 wing mirror cameras and a blind spot camera and sensor; then I could add a front and rear close range bumper camera for parking and use the last port for a GPS. Yes, it would be possible to use all inputs on an 8 port switch box. I think I'll start with the simple option first though.
James
Posted: 09:59pm 14 Feb 2013
James,
What about something like this... nice and cheap
Switcher
paceman
Posted: 01:14am 15 Feb 2013
  James_From_Canb said   What would be a good component to switch video signals?
Mick and TZ's suggestions are for composite video signals. Aren't we looking for a VGA video switch?
Posted: 10:04am 15 Feb 2013
Hi Paceman,
  paceman said  Mick and TZ's suggestions are for composite video signals. Aren't we looking for a VGA video switch?
I made that assumption as all cameras that I know of are composite types, I have never seen a VGA output camera, but they may exist.
If indeed James requires a VGA switch then he can use a device like this... Also cheap.
VGA switch
James_From_Canb
Posted: 12:35pm 15 Feb 2013
I should have said composite, not VGA.
Thanks for the tips.
James
paceman
Posted: 06:44pm 15 Feb 2013
  bigmik said   What about something like this... nice and cheap
Switcher
Thanks for that VGA switch link Mick, I just ordered one. I've been plugging /unplugging too long here.
Greg
