Forum Index : Microcontroller and PC projects : Ultra Small ARM processor
| djuqa Guru Joined: 23/11/2011 Location: AustraliaPosts: 447 |
Freescale has introduced the Kinetis KL02, World’s Smallest ARM Powered® Microcontroller
Only 1.9 x 2.0 mm, the Kinetis KL02 MCU features include: [quote=Freescale]48 MHz ARM Cortex-M0+ core, 1.71-3.6V operation Bit manipulation engine for faster, more code-efficient handling of peripheral registers 32 KB flash memory, 4 KB RAM High-speed 12-bit analog-to-digital converter High-speed analog comparator Low-power UART, SPI, 2x IICI2C 75cents Cost (in 100k Qty)[/quote] Link to release page Can't wait for an ultra compact evaluation board VK4MU MicroController Units |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4384 |
A bit like a small PIC32 but fewer peripherals. Not sure why either is interesting LOL John |
Because it is small and cheap enough to replace most 8, 12, and 16bit processors. VK4MU MicroController Units |
Does that not also apply to the cheap PIC32 chips? Also, does it have 5V-tolerant I/Os? Other snag I see is that it's Freescale. Reckon they'll be more open? Follow JTAG properly? Provide (free) support? Stick to standards? Not for me, thanks. John |
| pito Newbie Joined: 09/06/2011 Location: Posts: 25 |
Similar one (8kB RAM), from NXP: http://www.nxp.com/news/press-releases/2010/04/nxp-shows-wor ld-s-smallest-32-bit-arm-microcontroller.html LPC1102/1104 2.17x2.32x0.6 mm |
Clickable link Thanks Don't get me wrong, I love the PIC32, but these ARM chips are in a whole different league. VK4MU MicroController Units |
In what ways? So far none at all have been mentioned and questions remain unanswered... John |
For some embedded applications that amount of grunt in such a small package is impressive. When PIC32 is released in a 3mm Square package, I will be the first to embrace it as well. VK4MU MicroController Units |
David, As impressive as these ARM devices are, I cannot see myself using any unless they are attached to a header PCB.. 2mm x 1.9mm is smaller than the 10uf cap that most people are struggling with on the CMM. and it has 20 pins (by looking at the picture) or should I say `BALLS' within that confine. Is the 1.9x2.0mm size accurate or another example of "the US" not converting imperial to metric correctly? I cannot say I have ever seen a ruler that split mm any more than into 1/2mm steps and they are hard to distinguish at that. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| MOBI Guru Joined: 02/12/2012 Location: AustraliaPosts: 819 |
I suspect the size is correct as it is referred to as a "wafer level" chip so I guess that mean "un-packaged". I imagine it is a bit like those "black epoxy blob" chips you see inside digital watches and calculators etc. Either way, I don't think I'd be having a go at mounting one unless someone came up with a header board and in any case, the 100 pin TQFP is enough for me at the moment. David M. |
In any case it IS exciting... I can see these appearing in eBay and other places mounted on small PCBs with 4 legs as dedicated `do-it thing-a-me-jiggies' to add to your design easily... Say mini maths co-pro with or whatever they are programmed for. And selling for a couple of shekels including postage.
Bear in mind it's not very fast and has only small RAM plus very few I/Os. Don't get too excited. John |
I have just worked on an ULTRA-Small design using an 8051 Core, the ARM would have been same size but have a lot more grunt. The PCB for the entire controller had to be less than 6mm x 8mm due to the nature of the module. JohnS, I provided the info as this is the MicroController section, I thoguht some of the BackShed brigade MAY be interested especially as ARM processors are the most widely used 32Bit MCU VK4MU MicroController Units |
