Local Time 15:54 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CG CMM RTC battery.
Posted: 09:37pm 11 Mar 2013
The normal battery with 1307 RTC's etc, is the 2032 cell, but the CG board uses a much smaller battery.
What is the expected lifespan of this smaller battery over the ten years or so expected on the 2032 cell?
IT IS NOT A PROBLEM FOR ME - I am just curious as to the difference in lifespan between the two cells.
BobD
Posted: 01:01am 12 Mar 2013
Graeme,
what is the battery code used in the CGColorMax1? Plug in the battery code into Wikipedia and you can find out its capacity. You can then compare it to the CR2032. It will give you an idea of the batteries capability relative to the CR2032. The biggest factor in battery life is the time that the CGCM is powered off. I believe that the battery is not used when the machine is powered on. After all of the above you may be able to make a guess about the battery life.
Bob
Posted: 03:34am 12 Mar 2013
The current drain is so little that the limitation is the shelf life of this type of battery, which is 10 to 15 years.
CircuitGizmos
Posted: 05:52am 12 Mar 2013
The CGCOLORMAX1 uses the BR1225 from Panasonic. 48 mAh
The CGCOLORMAX2 uses the CR2016 at 90 mAh
The CGCOLORMAX2 has a place for a header or for wire connections if you want to remove the battery and hook up a different external battery.
