Local Time 15:54 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM: Directories
Juri74
Posted: 03:28am 14 Mar 2013
i'm a little bit confused about moving trough directories in a program..
suppose you have an empty sdcard with two directories:
GAMES
APPS
now chdir to directory GAMES
when in GAMES store path in a variable T$=Cwd$
now chdir to APPS directory
when in APPS directory if you type 'Chdir T$' you remain in APPS directory
why? could someone help please?
Juri
greybeard
Posted: 03:45am 14 Mar 2013
I suspect the path is relative to where you are. Try printing out what you have in T$ when you save the path.
To get to APPS from GAMES you would need to go up a directory level and then back down again. But what you are doing in your test code is trying to change directory from B:/GAMES to B:/GAMES/APPS instead of B:/APPS I reckon T$ only has "APPS" in it when you loaded Cwd$ into it. ( I may have the / the wrong way around but you should be able to see what I mean )
A good tip when something doesn't work is to print out all the variables to see what is actually in them.
cheers
Rod
Juri74
Posted: 04:14am 14 Mar 2013
Hello i tried a bit and i noticed that
the T$ variable appear to store the entire path (B:\GAMES or B:\APPS)
i tried by hands and it appear that if i remove the drive name the Chdir command start working
example i'm in APPS directory and i want to go to GAMES directory
if i type: Chdir "\GAMES" it work
but if i type: Chdir "B:\GAMES" it doesn't work
EDIT: probably Chdir should work in that way because the command Drive is used to change drive, i could type Chdir "A:\somedir" while i'm in B: drive...
i found a workaround my original line was "bkd$=Cwd$" (bkd$ is to back up path)
now is "bkd$=Right$(Cwd$,len(Cwd$)-2)"
thank you
JuriEdited by Juri74 2013-03-15
