Local Time 13:59 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Panel LED’s for CGCMM?
Posted: 04:00pm 22 Apr 2013
Hi all.
Not wanting to remove and resolder to the CGCMM so I can put the power LED and SD activity LED on the main panel, I heard that you can get some kind of fiber-optic stuff that is ideal for routing the light from SMD LED's to a panel so they can be seen from the outside of the case.
Does anyone know of such stuff and what it is called and where to get it?
I will have a search around on Element-14 now, but I don't know what they actually call the stuff, unless it is just called fiber-optic thread or something....
EDIT: Found these things at Jaycar....
http://www.jaycar.co.nz/productView.asp?ID=HP1192&keywords=l ight+transporter&form=KEYWORDEdited by Grogster 2013-04-24
Posted: 09:04pm 22 Apr 2013
Hi Groggy,
There is a fairly big range available HERE
Posted: 10:05pm 22 Apr 2013
Wow, those are excellent!
Thanks.
I will take a good look at those.
CircuitGizmos
Posted: 06:53am 23 Apr 2013
J21 on a CGCOLORMAX2 (TWO) connects to the 'power' LED.
I'll add one for the SD access LED on the next spin.
Posted: 01:00pm 23 Apr 2013
Not being critical, CG!
Just looking at a way to use the existing ones.
No need to redesign!
CircuitGizmos
Posted: 01:10pm 23 Apr 2013
No worries, Grog! I added the J21 header so that the power LED can be used as an extra output. Never thought to do it for the blue LED (SD card) but it costs nothing to add it to the next potential spin.
paceman
Posted: 05:10pm 23 Apr 2013
Hi CG,
If you do "spin" again it might be worth dimensioning for customers to optionally add one of those light pipes from Mick's link and add them to the package - that way it's still all SMD's. I see you've moved the resistors away from the LED's on the "2" (compared to the "1") but the LED's are probably still a bit too close to the card reader.
Greg
