Local Time 13:09 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mini Maximite load
vk4tec
Posted: 04:53am 13 May 2013
Guys
I have fired up my mini maximite with 3.0 volts all cool
I see the LED is flashing
Does that mean I have the switch in wrong ?
This is brand new out of the box kit from jaycar
Does it need a flash ?
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
vk4tec
Posted: 04:55am 13 May 2013
I think I got it
Programmed it up
LED on constant now
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 05:01am 13 May 2013
its alive !
Maximite BASIC Version 4.3A
Copyright 2011-2013 Geoff Graham
Andrew Rich VK4TEC
vk4tec
Posted: 05:29am 13 May 2013
Does the mini have the ability to run "AUTORUN.BAS" ?
Andrew Rich VK4TEC
CircuitGizmos
Posted: 05:34am 13 May 2013
  vk4tec said   Does the mini have the ability to run "AUTORUN.BAS" ?
Yes. It will run from internal memory if there is no SD card.
