Local Time 13:10 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pickit 3 programmer
vk4tec
Posted: 08:48pm 18 May 2013
Guys
I am guessing a pickit 3 programmer will do ICSP
I just need to map the programming pins to my PIC
16F628 16F877
Andrew
Andrew Rich VK4TEC
www.tech-software.net
MOBI
Posted: 01:46pm 19 May 2013
  Quote  I am guessing a pickit 3 programmer will do ICSP
Sure! I use it to programme blank PIC32s for the MM.
Do you have a pickit3?
Just connect the pins of the pickit3 to the pins on the pic with the same name and using MPLAB IDE or IPE should be a cinch.
You will probably need a 10K resistor from MCLR to +5v
If you need further info, just yell.
David M.
