Local Time 12:07 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Why? A Bug? What have I missed?
Nixie
Posted: 12:44am 03 Jun 2013
Greetings all. Have not been on for a while... Travelling...
Can someone tell me why this happens...please (using a B/W MM with 4.3a MMBASIC)
10 CLS
20 Input "Hours ";H
30 IF H=12 THEN ST=18:IF H=13 THEN ST=68:IF H=14 THEN ST=127
40 PRINT H,ST
If I enter 12, the result at line 40 is
12 18
If I enter 13, I get
13 0
If I enter 14, I get
14 0
However, if I enter each of the segments in line 30 on a separate line; then I get the correct results
13 68
And
14 127 respectively
Many thanks, Nic
MicroBlocks
Posted: 12:58am 03 Jun 2013
Everything after IF H=12 THEN will only be executed when H = 12
IF H=13 and the IF H=14 will never be true because that code is only reached when H = 12
Nixie
Posted: 01:23am 03 Jun 2013
Ah! Thankyou! Thankyou!
Think my logic is skiwiff!
Cheers, Nic
Posted: 02:39am 03 Jun 2013
Yes, it is a peculiarity of BASIC that everything on the line after the THEN is skipped if the test is false (this is documented in the manual).
