Local Time 10:05 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM-BMP085
palcal
Posted: 06:48pm 03 Jul 2013
I'm trying to read the values from the BMP085 temperature/pressure sensor. I am using the code posted by Olimex from Feb 2012 for the Duinomite. All I get is error messages. The sensor behaves as if it is not connected.
Does the code need changing to run on the MM.
Palcal.Edited by palcal 2013-07-05
palcal
Posted: 07:02pm 03 Jul 2013
Forget it. It helps to connect the pull up resistors.
