Local Time 09:24 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM one wire
palcal
Posted: 08:04pm 07 Jul 2013
This is an excerpt from the one wire routine;
GetTemp 18, Temp
Print "The temperature is:" Temp
' Subroutine to get the temperature from a Dallas DS18B20.
' The temperature is returned to the varable used for the
' second argument in the calling program
Sub GetTemp (PinNbr, Value)
Can someone tell me why the 18 in (GetTemp 18, Temp), is it the pin no.
if so I take it that 'PinNbr is the same pin'.
Also what is 'value' after 'PinNbr'
PALCAL.
MicroBlocks
Posted: 08:06pm 07 Jul 2013
I would guess that is an id number.
You can have many devices on that 1 wire so you need to address it.
If you show more code we can see how it is used.
Edited by TZAdvantage 2013-07-09
Posted: 08:51pm 07 Jul 2013
For anyone who is confused, Palcal is referring to the demo routine ONE-WIRE.BAS in the MMBasic Library downloadable from my web site.
PinNbr is the pin that the DS18B20 is connected to. You can use any I/O pin that can operate as open collector (ie, pins 11 to 20).
Temp is the variable that gets the result. Remember that if you use a variable in the parameter list the subroutine can change the value of that variable (which is what that subroutine does). See "Passing Arguments by Reference" on page 14 of the current MMBasic User Manual.
That demo was written before user defined functions became available. Nowadays you would use a function like this:
Print "The temperature is:" GetTemp(18)
' Function to get the temperature from a Dallas DS18B20.
Function GetTemp (PinNbr)
Local T1, T2, b, t
OWReset PinNbr ' reset
OWWrite PinNbr, 1, 2, &hcc, &h44 ' start conversion
Pause 100
t = Timer
If Timer - t > 1000 Then Error "Sensor not responding"
OWRead PinNbr, 4 , 1 , b ' conversion done?
Loop Until b = 1
OWWrite PinNbr, 1, 2, &hcc, &hbe ' command read data
OWRead PinNbr, 2, 2, T1, T2 ' get the data
GetTemp = ((T2 And &b111) * 256 + T1) / 16
If T2 And &b1000 Then GetTemp = -GetTemp ' adjust if negative
End Function
palcal
Posted: 09:25pm 07 Jul 2013
Many thanks TZ and Geoff, I understand.
Paul.
palcal
Posted: 11:19pm 07 Jul 2013
Well I thought I understood, but I keep getting a reading of zero. Maybe my sensor is kaput but it was OK in a picaxe project I was using.
I will try another DS18B20 when I get one.
Paul.
