Local Time 08:28 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SPI Problem
Frank N. Furter
Posted: 11:47pm 14 Jul 2013
Hi everyone.
I have to communicate with a TMC429 Steppercontroller via SPI.
The registers are 32 Bits long! I read in the manual that the Bit-Range is limited to 23 because the range is limited by how many bits can be stored in a floating point number.
I thought a single precision floating point number has 32 Bits???
Is there another way to send 32 Bits over SPI???
THANKS FOR HELP!!!
Frank
Dylan
Posted: 12:11am 15 Jul 2013
According to Appendix D, SPI sends bytes. But I'll leave it to experts on MMBasic and/or SPI.
A single precision floating point number has 32 bits. Your problem is that some of these are used for the mantissa, and some for the exponent (and 1 for the sign). http://en.wikipedia.org/wiki/Ieee_float#Basic_formats and all that.
MM_Wombat
Posted: 10:10pm 15 Jul 2013
Frank,
When I had to send 32 bits to some chips via spi then I just sent two lots of 16 bits before I reset the latch.
ie
'32 bits to send &hff88
temp1=&hff
temp2=&h88
Pin(17) = 0 'assert the enable line (active low)
junk1 = SPI(18, 19, 20, temp1, H, 0, 16)
junk1 = SPI(18, 19, 20, temp2, H, 0, 16)
Pin(17) = 1 'reset the enable line (inactive high)
maybe that would work..
Later I added some code to the source called spiDMD() which sent 32 bits each time, but was written to mirror the vga output to a Dot Matrix Display (DMD).
Dennis
[edit]
I assume the latch is the nSCS_S pin, with the clock as SCK_S and SDI_S as data in with SDO_S as data out..
from the datasheet
[/edit]Edited by MM_Wombat 2013-07-17
Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
Frank N. Furter
Posted: 08:42am 16 Jul 2013
Hello Dennis,
thank you very much!
Your code works very well!!!
I send four bytes with 8 bits with your (modified) code and can read all registers, I am very happy!
Thanks again!
:)Frank
