Forum Index : Microcontroller and PC projects : Duinomite (or ColorMaximite) & Midi
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
I just got 1 of these: http://shop.moderndevice.com/products/fluxamasynth The midi com standard says: 32.25 kbps 1 start bit 1 stop bit I can't figure how to get the start and stop bits ? The Duinomite will do the 32.25K but the manual (OPEN COM) doesn't mention # of bits or start or stop The ColorMaximite manual says the com is 8 data bits, no parity, 1 stop bit (only speed adjustable) Thanks for any insight .... |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4384 |
Chances are it's always 1 start bit and will actually be 1 stop bit. Try it :) I suppose you could look at the C code to see what it does... John |
Thanks .... Yea, looks like maybe the default settings are right. (though I'm not positive) Can't get a squeek though :( " For 8-N-1 encoding, only 80% of the bits are available for data (for every eight bits of data, ten bits are sent over the serial link — one start bit, the eight data bits, and the one stop bit)." |
You might need to invert the signal. Microblocks. Build with logic. |
| JTR0701 Regular Member Joined: 10/07/2013 Location: AustraliaPosts: 71 |
I think you will find that MIDI is 31.25kb/S and not 32.25kb/S. The start and stop bit are added by the PIC32 hardware UART and unless MMBasic provides an option for TWO stop bits then all the defaults are OK. As TZ points out you do need to be more concerned about compatible physical interfacing with your module, particularly with the polarity and voltage levels of the MIDI signal. The data sheet for the module should have this information. |
> I think you will find that MIDI is 31.25kb/S and not 32.25kb/S. Right. Senior moments. >The start and stop bit are added by the PIC32 hardware UART >and unless MMBasic provides an option for TWO stop bits then >all the defaults are OK. I hope so. >As TZ points out you do need to be more concerned about compatible >physical interfacing with your module, particularly with the polarity >and voltage levels of the MIDI signal. The data sheet for the module >should have this information. I'm pretty sure I'm good there. The synth normally goes on an Arduino board and snaps right on to the DuinoMite. Feeding it random numbers should get some noise if even the data was inverted but doesn't ... |
No! The start and stop bits would also be inverted. What you will get is framing errors on the MIDI module, not random sounds. |
I thought the 'start and stop bits' were automatic from the urt (independent of the data) ???? |
Yes, automatic but if they're inverted then you'll need to correct (reinvert) them. Do check the volts, too, as the PIC32 is a 3.3V device and maybe your Arduino is 5V? John |
Volts are OK 12V up from to Fluxamasynth 'shield' from DuinoMite Onboard 3.3V regulator, so synthchip is 3.3V Data coming up is 3.3V pulsetrain I need to look close at the chips data sheet. Maybe there is an initialization code or ???? |
Problem Solved ! http://www.thebackshed.com/forum/forum_posts.asp?TID=5938&PN =1&TPN=1 |
Excellent! |
