Local Time 06:42 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Duinomite standard power supply capacity
donmck
Posted: 11:23am 23 Aug 2013
Ben Semple just passed me on this information from Olimex, and I felt it may assist other DuinoMite users:
-----Original Message-----
Sent: Friday, 23 August 2013 8:33 PM
To: tripmeters
Subject: Fw: Duinomite standard power supply capacity
Hey Ben,
I just tested it empirically. I used Duinomite, powered by 12V
external power supply on the PWR jack and then I connected two 10 Ohm
resistors on the 5V line at the Arduino-like shield connector. At 12V
the power consumption of the bare board was 0.09A and when the load is
connected it goes up to 0.24A. I kept track of the 5V after the
MC33063 which was constant (around 5.1 Volts) before and after connecting the load.
In other words - the 5V rail might provide safely up to 200mA.
Best regards,
Lub/OLIMEX
This is for the standard DM power supply.
Cheers Don...
https://www.dontronics.com
Blackened
Posted: 11:47am 23 Aug 2013
That was timely! My project has reached a point where I was beginning to wonder what the upper limit might be.
Thanks for passing that on Don.
