Local Time 06:43 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Print @ mode bug?
panky
Posted: 11:56pm 13 Sep 2013
Hi Folks,
Playing around with the PRINT @ command I have found a problem using mode 5. My understanding of mode 5 is that repeated use of the command in the same position with the same character should invert the pixels under the character each alternate pass?
Has anyone else found an issue with this command and mode and confirm the bug or am I just missing something?
MMBasic 4.4 on a Duinomite Mega and 4.4 on a CGCMM1
Test Code
Cls
Font #2
x=18
Print @(1,1,0)"ABCDEFGH"
Pause 4000
Print @(1,x*2,0)"Space mode 0",@(13,1,0)" "
Pause 4000
Print @(1,x*3,0)"B mode 0",@(13,1,0)"B"
Pause 4000
Print @(1,x*4,0)"Space mode 1",@(13,1,1)" "
Pause 4000
Print @(1,x*5,0)"B mode 1",@(13,1,1)"B"
Pause 4000
Print @(1,x*6,1)"Space mode 2",@(13,1,2)" "
Pause 4000
Print @(1,x*7,0)"B mode 2",@(13,1,2)"B"
Pause 4000
Print @(1,x*8,0)"Space mode 0",@(13,1,0)" "
Pause 4000
Print @(1,x*9,0)"X mode 5",@(13,1,1)"X"
Pause 4000
Print @(1,x*10,0)"O mode 5",@(13,1,1)"O"
Pause 4000
Print @(1,x*11,0)"W mode 5",@(13,1,1)"W"
PS. I can understand why it may not work on the CGCMM but it should be OK on the Duinomite?
Cheers, Doug.
panky
Posted: 04:13pm 16 Sep 2013
Hi All,
Again, a victem of my own carelessness - mode 5 works fine on a mono Duinomite Mega running 4.4 (I had incorrectly tested on a DM running 4.3). It can be used to blink a character quite successfully - for Grogster, a possible cursor?
However, mode 5 does not work (understandably) on the CMM, it just works the same as mode 1.
Again, I am verry sorry to have wasted anyone's time on this,
Regards, Doug.
