Local Time 05:44 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 4 years
kiiid
Posted: 02:53pm 21 Sep 2013
Celebrating 4 years Dimitech and for a very short time - ICeemite from $19.95, DEB2-4105W40 at $0.95!
If anyone has wondered what these small modules are, now it is a good time to find out.
SHOP
http://rittle.org
Frank N. Furter
Posted: 12:58am 22 Sep 2013
Hello Kon,
that's a great offer! I would like to order 6x DTX2-4105C with MMBasic and 2x DEB2-4106W40.
But..., how can I pay it over PayPal? Can you send me an advice of payment over PayPal? - or must I am registered in your shop?
Thank you very much!
Frank
kiiid
Posted: 01:18am 22 Sep 2013
Hi Frank,
You don't need to be registered, neither you need to have a Paypal account. Just hit the checkout button and follow the instructions on the page. When you get to Paypal's page depending on whether you do have an account or not, select the relevant option. Without a Paypal account you can use a few types of cards directly.
If you have any problems, leave me a message or email contacts@dimitech.com
Thanks,
Kon
http://rittle.org
Frank N. Furter
Posted: 02:53am 22 Sep 2013
Hello Kon,
I ordered it!
Firstly I had problems with the shipping address - it must be filled out, but there is no hint that this is necessary. I thought the normal address is automatically the shipping address...
Thanks a lot!
Frank
Posted: 03:11pm 23 Sep 2013
Any plans for one of these with the A0-A5 and D0-D13 ports? It's COM2(D0/D1) I really need, which does not seem to be standard on your beast...
I fully appreciate and understand that you can't squeeze everything in!
Schematic says that RTC can only be in software, so I guess that means there is no RTC chip per-Se', and that you perhaps use the PIC32's native internal clock? If so, does that mean you have a special version of MMBASIC? IE: Can you update with Geoff's firmwares, or does it have to be via you guys? (i expect the latter, if you are doing things the way I think you are)
kiiid
Posted: 06:02pm 23 Sep 2013
Geoff's original MMBasic works fine with one exception - it does not allow SD write operations. You can download V4.4/R6 which is customised for the module, has the RTC support and some other extras missing in the original MMBasic. It is backwards compatible with Geoff's version i.e. will work on any other MM mono clone as well.
For the rest of your question - please check your private messages
Kon
http://rittle.org
Bryan1
Posted: 11:59pm 23 Sep 2013
Hi Kon,
Been that busy doing bathrooms I aint had time to spare for ages, now in your last post you said your version would work on any mono MM so is that the R6 version as I do have a couple here that would be good to try it on and having the help file will be the big bonus.
Regards Bryan
kiiid
Posted: 01:11am 24 Sep 2013
Hi Bryan, it's been a while since your last appearance. Glad to see you back.
Yes, R6 should work fine with the other mono boards.
KonEdited by kiiid 2013-09-25
http://rittle.org
Posted: 12:59pm 24 Sep 2013
Got your PM - thanks.
Frank N. Furter
Posted: 08:33am 09 Oct 2013
Hi Kon,
thank you very, very much for your fast delivery!
I received your parcel today!
Many Greetings
Frank
kiiid
Posted: 11:41am 09 Oct 2013
You are welcome :)
http://rittle.org
