Local Time 06:43 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Basic V4.4A and Duinomite MEGA
Lorenzo
Posted: 10:04am 22 Sep 2013
Hello,
Just one question:
After updating my mega in basic v4.4a, I noticed that the pin 11 is level high at boot , as I know on the mega duinomite pin 11 is connected to a com port, this may be normal ...
I still find it strange and troublesome.
So... Normal ?
Thank you for answer.
LorenzoEdited by Lorenzo 2013-09-23
Posted: 11:46am 22 Sep 2013
On the Mega pin 11 is driven by the on board RS232 interface, so it should be high which is the idle condition for serial I/O.
Are you saying that it was different in previous versions of MMBasic?
Lorenzo
Posted: 12:49pm 22 Sep 2013
Hi Geoff,
You are right, I tested since version 3... And It's the same thing.
It bothers me because I wanted the level is low at boot card, now, I think the only way is to unsolder the resistor connected to this port ..
I still think the Duinomite MEGA and EMEGA has not been very well studied by OLIMEX, add of some simple micro-switch and the user had the choice between two behaviors of some I/O ports of these cards ...as there are not many.
Thank you for the answer.
I am really impressed by your reactivity and quality of your work.
LorenzoEdited by Lorenzo 2013-09-24
