Local Time 05:45 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : UBW32 & MMBasic limitation ?
Dinosaur
Posted: 06:19pm 19 Oct 2013
Hi All
Looking to clock 16 stepper controllers from a UBW32.
Does anyone have any idea as to what the frequency limit
would be if I simply drive 16 outputs On / Off.?
PWM command would be handy if it was available for 16 outputs.
EDIT: Sorry meant to include "Using MMBasic"Edited by Dinosaur 2013-10-21
Hervey Bay Qld.
MicroBlocks
Posted: 06:54pm 19 Oct 2013
Do you mean servos, because you mention PWM?
I found it easier when i used MMBasic for the overall control and leave the timing critical parts, when using more then 2 servos, to other small microcontrollers connected to the i2c.
Dinosaur
Posted: 08:41pm 19 Oct 2013
Hi All
TZAdvantage, I meant Stepper.
By using PWM with 50 % duty cycle it is basically a good clock generator.
Hervey Bay Qld.
