Local Time 05:46 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Self adhesive front panel decals
trippyben
Posted: 08:23pm 24 Oct 2013
Hi all, now that PCB's can be ordered on-line out of china (or wherever) for excellent value at reasonable quality for small runs - does any one have a decal manufacturer they have experience with that have the same on-line presence and value for money?
Ben
MicroBlocks
Posted: 11:41pm 24 Oct 2013
I searched for that but ow my decal manufacturer is my inkjet printer.
I use sublimation inks and a polymer on an aluminum frontplate.
Then just use heat (with a special machine or when small an iron is enough) to transfer it. Works great and is scratch and waterproof.
Only thing i don't like is that sometimes the colors can be a little dark, you need to experiment a lot to get the right 'brightness' increase of the picture you want to print/transfer.
palcal
Posted: 12:33am 25 Oct 2013
I have not tried this yet, but you can buy a special transfer paper that you put in your printer and when printed is the same as the water slide transfers I remember from long ago. Have a look at http://www.decalpaper.com.au/products/inkjet-decal/clear/
Paul.
MicroBlocks
Posted: 01:17am 25 Oct 2013
I guess it all depends on the quantities you have to make.
I remember a thread here that used laminated prints with good success.
Can you give an example of what size and quantities you need.
Full color or is pad printing (can be 1-6 colors, put is not good for things like pictures) also a solution.
I might be able to find something here in Thailand that can do that kind of job.
But i need more info to get a quote from them and even if they can do it.
Edited by TZAdvantage 2013-10-26
trippyben
Posted: 12:19pm 25 Oct 2013
Selfies aren't an option.
Usually do in batches of 50, 138x76mm, clear window for LCD 65x35. 3 colours.
I currently get them done locally, quality is OK. I have a new one to add to the mix, doesn't hurt to shop around.
