Local Time 05:45 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with reading I2C
Frank N. Furter
Posted: 02:19am 28 Oct 2013
Did anyone tested the I2CRCV command with only on Byte and an "normal" variable?
I have to communicate with a ISL29023 light-sensor and want to read only one byte.
When I use the example "I2CRCV &h6f, 1, 1, avar" (or when I use my address with my variable) I get an error: "Error: Invalid variable" ???
...but it works very well when I use an array and read my data in only one cell!!??
Doesn't work:
I2CRCV &H44, 0, 1, test
Work:
DIM test(1)
I2CRCV &H44, 0, 1, test(0)
What's going wrong?
THANKS!
FrankEdited by Frank N. Furter 2013-10-29
Posted: 02:29am 28 Oct 2013
Maybe it requires an array, no matter what result(s).
Posted: 02:46am 28 Oct 2013
It could be because the variable has not been previously used.
Try this:
test = 0
Did this work?
Disclaimer: I did not write the I2C stuff.
Frank N. Furter
Posted: 08:34pm 28 Oct 2013
Hi Geoff,
very good Idea!
...and it works!!!
I get no Errormessage when I use the variable before and my code works, I can read out my sensor!
THANKS!
Frank
Posted: 04:55am 29 Oct 2013
Thanks for the feedback, I will fix it in the next version.
