Local Time 04:54 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Exit Do
Dinosaur
Posted: 08:49pm 10 Nov 2013
Hi All
Just spent hours trying to find a simple error: Unexpected Text
This is mainly aimed at Geoff.
We have:
Exit Sub
Exit For
Exit Function
Why do we only have Exit instead of Exit Do ?
Hervey Bay Qld.
Posted: 11:38pm 10 Nov 2013
Excellent question and I don't know why !
At the time (over two years ago) I was following BW BASIC's syntax as they claimed that they were ANSI or GW Basic compliant. But on re reading the ANSI standard they use EXIT DO and GW Basic does not have a DO LOOP. Visual BASIC does and it also uses EXIT DO.
The fix is easy, I will add EXIT DO to the next version. I will also leave just EXIT on its own in the language so that old programs can continue to run.
Dinosaur
Posted: 06:04pm 11 Nov 2013
Hi All
Thanks Geoff.
Worth noting that FreeBasic also uses Exit Do
and that is why I was so puzzled by the error.
Hervey Bay Qld.
