Local Time 04:53 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : UBW32 Interface Boards
Dinosaur
Posted: 10:04pm 16 Nov 2013
Hi All
I have used the ubw32 for a few years now, and have manufactured a few boards to interface to it. These are all used on industrial weighing machines.
I even got the usa to write some code to implement a phase angle firing program
with eight outputs.
However, I have now "retired" and some old customers are interested in replacing my
boards with "off the shelf" boards.
I am looking for a 24 vdc input board,
and an output board for opto relays.
Typically no more then 4 inputs and 8 outputs.
I have seen some boards on this forum, but not sure
how long these will be available.
Searching on the web for "UBW32 Interface boards" proved fruitless, so I am hoping some of you guys have sourced or implemented Arduino boards for this purpose.
Any suggestions ?
Hervey Bay Qld.
donmck
Posted: 07:14pm 17 Nov 2013
  Dinosaur said   Hi All
Any suggestions ?
Don't know if this will help:
I have boards that I post out as an Air Mail letter. You can just populate with what you need.
Two boards, but it will get you from the UBW32 to an Arduino shield.
this will get from UBW32 to a 26 pin header.
http://www.dontronics-shop.com/ubw32-mcc-pcb-letter.html
This will get you from the 26 pin header to an Arduino footprint.
http://www.dontronics-shop.com/donduino-cross-letter.html
As I say, it may or may not assist, but if you don't know, it definitely can't help you. :-)
Don...
https://www.dontronics.com
