Local Time 04:08 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I think I’ve had a Katharsis !
hitsware
Posted: 03:54pm 10 Dec 2013
When you run a Duinomite via 'terminal' (usb to PC)
The graphic output does not show up on the screen ......
Vs when the keyboard (and monitor) are directly hooked ....
paceman
Posted: 04:43pm 10 Dec 2013
Err.. - yes Michael - page 9 of the manual - Graphics
Graphics commands operate on the video output only (not USB).
You're not the first to miss it though so don't beat yourself up! Geoff doesn't mention that under "Keyboard/Display" on the Functional Summary (p3) but it probably rates a mention there.
hitsware
Posted: 05:25pm 10 Dec 2013
  paceman said   Err.. - yes Michael - page 9 of the manual - Graphics
Only makes sense ....
Never even thought about it until CLS
did not respond ... Duh
Bryan1
Posted: 11:16pm 10 Dec 2013
I'm currently running a DM mega and testing out my DS18B20 temp sensors for a couple of projects I have got in the line and I found tera term to work fine while I had a monitor going. I do find writing code on the pc then just send the files via xmodem does the job nicely so I get the file to be transferred all ready then type the command using the ps2 keyboard on the DM. Then hitting enter on both the pc and the ps2 and next thing the file is on the SDCard.
Just tried a few commands via USB and everything worked fine.
Regards Bryan
hitsware
Posted: 04:31pm 13 Dec 2013
EDIT :
Both DuinoMite and ColorMaximite work with
Minicom using either TinyCore or Slax Linux.
AND:
Both will write to the terminal screen.Edited by hitsware 2013-12-16
