Local Time 03:08 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TFT-Maximite understanding commands
Juri74
Posted: 02:50am 17 Jan 2014
hello all again..
i'm a little confused about commands "touched(#x)" and "touched(y#)"
manual report:
This will return the current x or y coordinate of the current touch point of the screen.
if the screen is not being touched -1 will be returned.
now type this little program:
Print Touched(#x),Touched(#y)
'Touch release
loop
when you touch the screen coordinates are displayed, but when you remove the finger from screen last point pressed continues to be displayed (no -1 is displayed even without finger on screen)
if you uncomment the "Touch release" command all works fine but the program is halted when you touch the screen
is this a normal behaviour?
EDIT: referred to mmbasic v4.4b
thank you
JuriEdited by Juri74 2014-01-18
Juri74
Posted: 01:28am 18 Jan 2014
another piece of code that, apparently, doesn't not work:
Touch interrupt beep
Do:Loop
beep:
Touch Beep 100
Ireturn
any help?
Juri
