Local Time 23:22 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD init error
MOBI
Posted: 07:28pm 19 Mar 2014
Decided to swap from i2c LCD to uMite version but keep on coming up with "invalid pin" error.
LCD init 21,3,2,9,10,16
do
loop
will work, but,
LCD init 21,3,2,9,15,16
do
loop
will not???
According to my understanding of the uMite instructions the pins I am trying are valid and the syntax correct.
I don't think that is the only combination that will not work. Is it just my tired eyes or a critter?
edit===============
further probing seems not to like pin 15.
Edited by MOBI 2014-03-21
David M.
palcal
Posted: 11:02pm 19 Mar 2014
If you are using the 250 chip Pins 15 and 23 are not valid.
Paul.
Posted: 11:17pm 19 Mar 2014
As palcal says, chances are you are using a PIC32MX250.
If you are using a 150 then that pin is faulty (assuming all your connections are good.
My money is on the fact it's a MX250 . . . .
Please confirm back if this is the case!
MOBI
Posted: 12:47am 20 Mar 2014
  WW said  My money is on the fact it's a MX250 . . . .
It is indeed the 250. I have three 150s, I'll try one of them.
Does pin 15 of the 250 have any uses or is it totally kaput?
David M.
MOBI
Posted: 12:58am 20 Mar 2014
  paul said  If you are using the 250 chip Pins 15 and 23 are not valid.
Paul.
Just changed to the 150 and all is fine. Pity about 15 and 23 on the 250 as it leaved bugger all for hardware using the keypad and LCD. especially as 17 and 18 are needed for i2c RTC.
Does anybody want 3 slightly useless 250s?
David M.
MicroBlocks
Posted: 05:47am 20 Mar 2014
HI Mobi, i could have a use for those.
Maybe we can make a trade.
Posted: 06:34am 20 Mar 2014
Hats off to Geoff as this is all very clearly explained on Page 4 in the (Beta 16) manual.
Personally I would only use the PIC32MX150's simply so that I avoid this situation. Several people have fallen into this trap here on the BSForum!
Also worth noting that directly from MicroChip (and they are generally cheaper than every other parts supplier), the PIC32MX150 is 10% cheaper per unit than the PI32MX250.
Simply rule, if you have some spare 250's lying around that you wish to use, then you only have 17 I/Os compared to 19 I/Os. The shortfall of two I/Os are on Pin 15 & Pin 23. For all new designs it makes sense to buy 150's.
MicroBlocks
Posted: 08:09am 20 Mar 2014
I will use them for some pinguino32's.
They are arduino compatible and use the USB port with bootloader.
I can trade them for the PIC32MX150, dip or soic version.
MOBI
Posted: 12:40pm 20 Mar 2014
  Wiz said  Hats off to Geoff as this is all very clearly explained on Page 4 in the (Beta 16) manual.
I think I had better re read the manual in its entirety instead of assuming that "cut and dried" sections did not reflect changes. Could have saved me some headache.
  TZA said  I will use them for some pinguino32's.
Is it really postage cost effective to swap? As I do most of my interface via i2c, especially LCDs, I can afford to lose a couple of pins.
It is a cold and rainy day here so I'll sit down and do a complete re-read of the manual to see what else I've missed.
David M.
