Local Time 19:02 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Max Com1 Data Rate
VK2MCT
Posted: 04:08pm 19 May 2014
Hello Gents,
I wanting to use the uMite to read a 250Kbps serial port, but the manual says that Com1 max is 230.4Kbps (tantalizing close).
If the CPU speed is increased to 48MHz (from 40MHz default), Com1 max is still 230.4Kbps according to the manual.
Can anyone suggest a way of achieving 250Kbps ?
John Berry.
Posted: 07:06pm 19 May 2014
The firmware will actually let you go to 2823529 baud at 48MHz.
Posted: 07:09pm 19 May 2014
Something extra for the next release of the manual then?
VK2MCT
Posted: 02:54am 21 May 2014
Thanx Geoff.
On Uarts, are the Uart registers available via peek or poke ?
At the moment I'm pretty confused about memory mapping in the umite.
John Berry
Posted: 03:15am 21 May 2014
Yes they are, although you will have to decode the data sheet to find their address and functions. For example the addresses of the registers controlling UARTS 1 and 2 are listed in page 49 of the PIC32MX1XX/2XX data sheets.
GeoffEdited by Geoffg 2014-05-22
