Local Time 19:02 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS18B20
ajkw
Posted: 01:51am 22 May 2014
I have recently introduced a DS18B20 into my current project on a Mircomite (v 4.0503) and whilst I have had no issues communicating with it I have found that the program will crash if the positive power, in external power mode, to the DS18B20 is accidentally disconnected. If you 'accidentally' disconnect the ground or data wire I get a returned value of -127.938
I have been using the built in command, DS18B20(pin)
Anybody with any other experience with this?
vasi
Posted: 04:34pm 22 May 2014
I guess that is a normal behavior.
A good 1wire library should return error codes like:
- sensor not found;
- short circuit;
- bus error
etc.
____
Anyway, as it is, it provides basic functionality which is a good thing if is for learning or simple applications. A complete library, designed against any accident is much bigger.
A good library (as an inspirational source) can be found here:
http://siwawi.bauing.uni-kl.de/avr_projects/tempsensor/ Edited by vasi 2014-05-24
Elvish name: Mablung Miriel
Beyound Arduino Lang
