Local Time 15:39 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Silicon Chip USB Data Logger
BobJa
Posted: 07:37pm 26 Jun 2014
Problems with USB Data Logger
I recently purchased the USB data logger kit from Altronics featured in SC Dec 2010 – Feb 2012 and it refuses to work correctly. The host program and drivers have been downloaded from the Silicon Chip website and appear to be working correctly. Sample scripts can be run on the host, however when the script is compiled and sent to the logger the blue LED flashes continuously and can only be stopped by disconnecting the USB or removing the batteries. The start/stop pushbutton has no effect. All voltages are correct. Also a number of the sample scripts when run from within the host program bring up errors.
Unfortunately the support for this kit appears to be limited. Are any other readers experiencing the same problems?
BobD
Posted: 08:28pm 26 Jun 2014
There has been some forum activity about this unit. A Google search of the forum may give you some help.
Click here
norcold
Posted: 10:37pm 26 Jun 2014
I had no joy running this data logger on battery, but it performed correctly powered by USB continually. Considered at the time I had constructed incorrectly but feel now it has problems. Suggest you power it up using USB and take from there.
Vic
BobJa
Posted: 04:04pm 28 Jun 2014
Thanks for the suggestions.
I can't get the unit to work when powered by USB or batteries.
There seems to be some inherent problems with the logger. I have contacted SC and will wait on their thoughts, unless anyone else has further ideas?
