Local Time 15:39 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite / VT100 comms. oddity
jsand
Posted: 10:16pm 02 Jul 2014
Hello BackShed,
I've just got my PIC32 going with the Micromite 28pin hex loaded
and the led blinker program working, so I'm proud that the platform
is up and running.
Setup is:
IBM Notebook PC with a real serial comms port (COM1).
Running Tera Term as console.
Micromite flashed using MPLAB, Microstick II etc.
PIC32MX250F128B.
On inital power-up all I got was garbage on the console, but at
least it was garbage instead of nothing. Evidently the Micromite was alive.
Inspection showed the Rx/Tx lines looked to be running inverted.
So, I hooked in a CMOS 4xxx to invert them again & the whole
thing ran sweetly.
My question: Why the need to invert?
rgds, John
Posted: 10:31pm 02 Jul 2014
Very common thing, and nearly always needed. Page 57 & 58 of the MicroMite manual describe a low-cost 232 interface though. You still need a level-corrector for the console though.
TTL is 5v(or 3v3) logic, but RS232 is 15v logic.
I'm not sure why exactly, but RS232 being what it is, is simply not compatible at a voltage level end of things, and no idea really, why they decided to make RS232 inverted(idle-low), and TTL true-logic(idle-high). There WILL be a reason, but I am not sure what that is - others will probably chime in with reasons.
As long as I have EVER done ANYTHING with com ports, I have ALWAYS needed a level corrector like a MAX232 in-between any 5v(or 3v3) logic, and a PC - C'est La Vie...
Oh, and welcome to the forums, and congratulations on you working out what the issue was - well done you, and I now hope you get many happy hours of experimentation from your MicroMite. Edited by Grogster 2014-07-04
