Local Time 14:44 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 8-Bit Basic Computer
elproducts
Posted: 02:03pm 13 Jul 2014
Interesting Basic Computer built around and 8-bit device and completely easy to built DIP package.
Wonder if this could be done with a PIC18F and Great Cow Basic.
More Info Here
www.elproducts.com
Posted: 03:15pm 13 Jul 2014
Looks interesting.
Lou
Posted: 03:57pm 13 Jul 2014
el,
I would be interested if it were a PIC.
When the summer chores are done in Oct or so I'm going to seriously try CGB.
Lou
djuqa
Posted: 10:53pm 13 Jul 2014
Looks like a 8bit wannabe maximite/micromite that sort of works.
VK4MU MicroController Units
Posted: 11:15pm 13 Jul 2014
  djuqa said   Looks like a 8bit wannabe maximite/micromite that sort of works.
HAHAHA!!!!!!
vasi
Posted: 02:16am 14 Jul 2014
If PIC18F has to be involved, it must be a 64MHz capable device 'cause it will match the ATmega1284P speed at 16MHz. P18F46K22 is a 40 pin device with 64Kb FLASH (do we have one with 128Kb?) and 4KB RAM (that ATmega has 16Kb RAM - a monster). Good for Dk-Basic.
The SPI, I2C and Analog pins on ATmega are available on those free ports...
I think it is possible if the TV-out thing can be implemented.
Anyway, I guess Microchip complicate too much the peripheral thing... too many features are battling for the available pins...
____________
It will be much more useful if it comes designed for Gameduino 2 (and then, things are simplifying much more as you can use Firewing BASIC). Worth a try?Edited by vasi 2014-07-15
Elvish name: Mablung Miriel
Beyound Arduino Lang
vasi
Posted: 02:40am 14 Jul 2014
Oops. in the actual implementation, around 8Kb of RAM are used for Video frame buffer. A gameduino 2 (or even one from Olimex) is a requirement. And with Dk-Basic (bytecode compilation) you can make a better 8bit computer. Still, too less RAM on PIC18F!
From the comments, there is a tip regarding Video:
[quote]Just a tip from someone who built this before: try using SPI2X for serializing the video output, or alternately use a 74165 PISO. You'll get much better video resolution, definitely worth it. [/quote]Edited by vasi 2014-07-15
elproducts
Posted: 03:29am 14 Jul 2014
PIC18F67K22 has 128k and 3.8k RAM but its a 64 pin part so you lose the DIP package.
I didn't see any reference for the Gameduino requirement.
Oh well,
Just nice to see more people trying to keep BASIC programming alive and fun.
Hard to beat the Maximite/Micromite though.
www.elproducts.com
vasi
Posted: 03:41am 14 Jul 2014
  elproducts said  ...
It becomes a requirement if you want to do your own using a PIC18F as you don't have a 8Kb of RAM for the video frame buffer. On other words, you give up on generating video signal using the microcontroller and you have more features for the BASIC interpreter. I thought my comments where clear enough... I have to work more on my English. It is everything there, in your link...
vasi
Posted: 05:55am 14 Jul 2014
Great Cow Basic compiler for PIC18F46K22 is better than any 8bit BASIC computer, including and ATmega based one...
Chipino will gain more if is backed up by a powerful 8bit microcontroller, and then can be a real alternative to Arduino.
