Local Time 14:44 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Read GPS & Transmit
edu001
Posted: 07:08am 15 Jul 2014
Hi
I have just purchased my first micromite
The programme I have in mind requires that I receive GPS Data on COM1 and transmit on COM2 is this possible ?
PicFan
Posted: 08:31am 15 Jul 2014
Yes, i think it is possible, i can not see a problem.
Posted: 08:40am 15 Jul 2014
Hi edu001,
As PicFan says, this is possible. If you have any questions then do post them on this forum because there are plenty of people willing to help.
Why not give more details as to what you wish to achieve so that you may get inspiration from other members.
Good luck with your first project . . .
WW
edu001
Posted: 10:27pm 15 Jul 2014
Thanks for the reply
What I am trying to do is read the gpgga NEMA data from the GPS (COM1) 9600 baud
Read the temp from the DS18B20
Then combine the 2 into a string and send to COM2 set to 50 baud
halldave
Posted: 02:30am 16 Jul 2014
As a suggestion use this example code to read GPS Com1:
http://geoffg.net/Downloads/Micromite/GPS_Clock.bas
' Define your Temp Port
DS18B20 START 15 ' connect to port 15
OPEN "COM1:4800" AS #1 ' open the GPS serial interface
OPEN "COM2:50" AS #2 ' open your port to write to
' read some GPS Data, refer to GPS_Clock.bas
' write to Com2:
print #2, "Temperature: ",DS18B20(pin)
