Local Time 12:02 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CGMMSTICK1 Updated, now will not start.
OldMMUser
Posted: 03:11am 10 Aug 2014
Hello,
I received a new CGMMSTICK and after some "fun" getting it to work with Windows 8
I tried some of the MMBasic examples. Most worked well.
Some of the MMBasic programs complained that certain commands were not implemented in the version of MMBasic on the CGMMSTICK1 (4.0).
I followed the firmware update process (to 4.5)to the letter and it seemed to work perfectly.
Now when I plug the stick into the USB port the green power LED does not turn on. I re-installed the USB software (set to COM:3) and I get a yellow triangle over the USB symbol in the hardware manager.
Does the CGMMSTICK1 REQUIRE the version 4.0 firmware to work properly?
(Worried now about my 'broken' stick...)
Any help would be GREATLY appreciated!
Justplayin
Posted: 05:10am 10 Aug 2014
I have two CGMMSTICKs and have updated both to MMBasic 4.5 without any problems. My first thought is that you may have used the wrong firmware. Did you use the firmware for a monochrome Maximite?
--Curtis
OldMMUser
Posted: 06:18am 10 Aug 2014
Thank you!
I could have sworn the CGMMSTICK was color and that is what I used!
Using the monochrome firmware the device runs 4.5 without a problem!
Many, many thanks!
Whew!
Posted: 01:23pm 10 Aug 2014
Glad you got it sorted, and thanks for posting back to let us know.
Justplayin
Posted: 06:49am 11 Aug 2014
Great!!
Wish I could say I knew what I was talking about... But, it really was just a wild guess!
--Curtis
Posted: 08:13am 11 Aug 2014
When I initially started playing with MaxiMites, I came across the CGMMSTICK, and I assumed the 'C' in CGMMSTICK meant 'Colour'!!
Good Guess Curtis
WW
