Local Time 11:06 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD 16x4 MMBasic issue
akashh
Posted: 02:38am 12 Aug 2014
I have MMBasic 4.5 for Duinomite and I am using a 16x4 LCD. The positioning works great on the first 2 lines, but lines 3 and 4 shift the characters to the right. Position 1,3 is about 6 or 8 chars to the right, same goes for line 4. Did anyone else have this problem and if so is there a fix?
Thanks,
Akash
CircuitGizmos
Posted: 03:34am 12 Aug 2014
There is another thread that discusses this.
Some LCD displays have slightly different locations for where lines 3 and 4 start in memory.
I suggested a work-around using the built-in LCD command and a little additional logic wrapped in a subroutine.
Posted: 06:57am 12 Aug 2014
with a bit of luck, with the next release of micromite basic geoff may be able to add some way of adjusting for the differing memory location. has anyone made a close examination of the different controller datasheets to determine how many variations there are? syntax-wise, specifying a line of 3a, 4a could indicate an alternative offset. eg:
LCD 3A, C20, "this is a test"
i'm picking that there are most likely only a couple of variations, perhaps 3 at most.
rob :-)
G8JCF
Posted: 08:26am 12 Aug 2014
This may help you.
Adapted from my I2C LCD library. These numbers worked for me with a 20 x 4 LCD, so maybe you can try, and if needs be adjust the numbers.
73
Peter
' Print String to LCD
SUB LCD_(LineNum,CharPos,Text$)
LOCAL I
IF LineNum=1 THEN I=(&H80 + CharPos-1)
IF LineNum=2 THEN I=(&HC0 + CharPos-1)
IF LineNum=3 THEN I=(&H94 + CharPos-1)
IF LineNum=4 THEN I=(&HD4 + CharPos-1)
LCD CMD I
FOR I=1 TO LEN(Text$)
LCD DATA ASC(MID$(Text$,I,1))
NEXT I
END SUB
Edited by G8JCF 2014-08-13
The only Konstant is Change
akashh
Posted: 03:26pm 12 Aug 2014
Great, thanks for the suggestions! I will try them out as soon as I can get around to it!
Akash
flowerpetal
Posted: 03:25am 26 Aug 2014
first character on third line for a 16x4 will be 0x10 in DDRAM but for 20x4 it will be 0x14,(fourth line 0x50 and 0x54 respectively) so you would have to adjust your coding to suit.
