Local Time 11:07 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : is it possible to name a PIN ?
f1fco
Posted: 12:03pm 19 Aug 2014
hello to all,
a simple question :
if I want to light a led, I use this program :
SETPIN 11,DOUT 'pin 11 is digital output
PIN(11)=1 'the led on pin 11 light !!!
is it possible to give a "symbolic" name to a pin ?
exemple :
led=11
SETPIN led,DOUT
led=1 'or led=high ?
in ARDUINO, I can write : int led = 11;
or also : #define led 11
is it a solution in MMBasic ?
thank you for answer and solution
Pierre
73s de F1FCO
Posted: 12:17pm 19 Aug 2014
You could use a sub.
led 1
sub led(x)
Pin(11)=x
end sub
Bit crude, but would work.
Justplayin
Posted: 01:08pm 19 Aug 2014
Yes, you may use variable names instead of the actual pin number. The following code will blink the power led on a Maximite.
Top:
led = 0 ' pin 0 is the Maximite power LED
Pin(led) = 1 ' turn it on
pause 200
Pin(led) = 0 ' turn it off
pause 200
goto Top ' repeat
--Curtis
halldave
Posted: 03:15pm 19 Aug 2014
xOn=1
xOff=0
xLED=11
SETPIN xLED,DOUT
For Counter = 1 to 100
Pin(xLED)=xOn
Pause 1000
Pin(xLED)=xOff
Pause 1000
Next Counter
f1fco
Posted: 10:24pm 19 Aug 2014
thank you for answers and ideas
I like the code from HallDave
I try
high=1
low=0
led=11 'digital output for a led
info=10 'digital input for a button, pull up to VCC
led=low 'led is off
DO
IF info=low THEN 'if I push the button
led=high 'the led light
ELSE
led=low
ENDIF
LOOP
I like the way to name inputs and outputs pins in the top of the code
it is easy to change...
and the name (led, buzzer, siren, relais1, relais2... is much easy to understand)
thank you again
Pierre, at Nimes, south of France
hamradio F1FCO
73s de F1FCO
f1fco
Posted: 12:43am 21 Aug 2014
the previous code do not run
the following to blink a led is OK
high=1
low=0
led=11
SETPIN led,dout 'digital output for a led
Pin(led)=low 'led is off
DO
Pin(led)=high 'or =1
Pause 500
Pin(led)=low 'or =0
Pause 500
LOOP
it is a "smart" way to name pins
Pin(led) is meaningful than Pin(11) and you can name the I/Os pins in the top of the program
ti ti ti ti ti ti 'end of transmission
F1FCO, Pierre
73s de F1FCO
