Local Time 10:10 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMite in the ColorMaximite .....
hitsware
Posted: 04:48pm 30 Aug 2014
... Sea of holes .....
Could you communicate with a stock chip ?
Posted: 06:12pm 30 Aug 2014
If you mean could you put a MicroMite in the sea-of-holes in CG's CMM unit, and then talk between them, then yes - no problems. Use either I2C or serial.
hitsware
Posted: 02:50am 31 Aug 2014
Could the CMM simply act as (in the same way) a VT100 ?
Posted: 02:01pm 31 Aug 2014
Yes, but you would have to write a terminal code for the CMM in MMBASIC.
Do-able, but I would just go for the existing VT100 unit - why re-invent the wheel?(rhetorical)
