Local Time 10:10 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : is it possible to use PIC32MX170 ?
f1fco
Posted: 11:32am 31 Aug 2014
hello to all,
I order and I receive from Micochip Direct 2 pieces of PIC32MX170F256D-50I/PT
is it possible to use it in a MicroMite in place of PIC32MX150 ?
with more memory...
what HEX file for it ? is it possible to compile the source of MMBASIC for this PIC32MX170 ?
thanks to Geoff
Pierre, south of France
73s de F1FCO
G8JCF
Posted: 12:37pm 31 Aug 2014
Hi Pierre
You can certainly load the existing 4.5 uMIte .HEX file into a 170F but you will get no more memory until Geoff generates a new uMite MMBasic .HEX file specifically for the 170F which I understand he is creating/going to create.
So kep those 170F's on ice until then
73
Peter
The only Konstant is Change
f1fco
Posted: 08:05pm 31 Aug 2014
hello Geoff,
can you help me with a "special" version of MMBasic HEX file re-compiled for a PIC32MX170F256D-50I/PT ? (44 pins)
thank you VERY much
Pierre
73s de F1FCO
Posted: 09:10pm 31 Aug 2014
Hi Pierre,
Geoff is fully aware of the MX170 file requirement and will release a .hex file when he is ready to do so.
For now, you can simply use the 150 .hex file (for the 44-pin) and everything works exactly like it runs on a 150.
As Peter says, you will not get the benefits of the additional memory BUT at least you are able to currently buy the MX170 for use in your project(s) without having to wait for MicroChip to produce more for the global market!
If you have any more questions regarding the MX170 then feel free to ask. I am using them on my 44-pin Module without any issue.
WW
Posted: 04:59pm 01 Sep 2014
This has turned out to be more complex than I first thought it would be.
Firstly, I had used my sample MX170 chips in another project and when I went to order more Microchip quoted me a lead time in months. However, WhiteWizard came to my rescue and sent me one of his 44-pin modules with a MX170 installed.
Then, when I went to build MMBasic for the MX170, I found that Microchip have not released the MLA library for the MX170. I won't go into the details but MMBasic makes extensive use of the MLA library and now Microchip expect you to completely rewrite the firmware to use their Harmony library instead.
Harmony has a huge number of issues and you can read my rant on this subject here:
http://www.thebackshed.com/forum/forum_posts.asp?TID=6555
Anyway, by modifying the compiler installation I have fooled it into building MMBasic for the MX170 while using the MX150 MLA library (the chips are identical except for the greater memory capacity).
You can download the new version from this thread:
http://www.thebackshed.com/forum/forum_posts.asp?TID=6902&PN =1&TPN=1
GeoffEdited by Geoffg 2014-09-03
f1fco
Posted: 08:22pm 01 Sep 2014
hello Geoff,
merci beaucoup (my english is bad)
a lot of THANK YOU
Pierre, city of Nimes, south of France
73s de F1FCO
G8JCF
Posted: 03:36pm 02 Sep 2014
Hi Pierre
When I lived in Brussels we used to say "Merci Bien", was that a Belgium French variation on "Merci Beacoup" ? (I was taught 'Merci Beaucoup' at school)
Merci Bien
Peter
Posted: 10:34am 04 Sep 2014
I have been using a MX170D (with MMBasic 4.5D) for the last few days now and can say that it has been really fantastic to use - and absolutely no issues whatsoever to report. Nice work Geoff on 4.5D
However, there seems to be another global shortage of these chips on the way (probably not helped by me ordering a large volume ). Anyway, for anyone interested in securing either a 28-pin or a 44-pin MX170 then this is to let you know that I am now in a position to offer these at MicroMite.org (pre-programmed with v4.5D).
I have had many emails asking about the MX170 being installed on the 44-pin MicroMite Module. I will begin shipping these with MX170's installed as soon as I have the next batch of PCBs from the fabricators (due in about 2 weeks time). For everyone that has placed back-orders for the various MX170 modules then I can now reassure you all that I have secured all the PIC32MX170s required.
Anyone wanting a MX150? I still have a few left in stock. However, with over double the memory capacity, I recommend migrating to the MX170 for all new designs.
WW
