Local Time 10:10 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS18B20 Function
DaveC166
Posted: 09:07pm 31 Aug 2014
I am currently building a 28 pin micromite HRV controller to replace a Picaxe 28x2.
I have 3 DS18B20 sensors connected,2 using parasite power and 1 normally powered,all three with 4.7K pullups,default resolution .
The DS18b20() function only seems to work above zero degrees. Below zero degrees all 3 sensors return -127.00 degrees whether it is actually -0.5 to -10.0 deg. any one else encountered probs with DS18b20 sensors at below zero temps. Do I have to use one wire functions?
Posted: 09:17pm 31 Aug 2014
@DaveC166, I'm so glad you posted this - I seem to have seen a similar issue.
I am helping someone use a DS18B20 as a temperature sensor in an application where temperatures fall to around -75 degC. In tests we also notice the temperature returning -127 (but I'm sure we did get some -ve readings - will check this).
So yes, I have seen it too. I was going to do more tests today (using the freezer) to see if it is a -ve temp issue. I get the feeling there may be a small bug in the firmware.
I will try bit-banging first to make sure the temp sensor isn't faulty - and then post again to let you know what I find.
WW
DaveC166
Posted: 09:34pm 31 Aug 2014
Thanks.
That's what I tried, sticking all 3 sensors in the freezer one at a time. all were ok until 0 deg c. Even just below 0 they all return between -125 deg and -127 deg
I guess the onewire function is the only alterative
Posted: 09:41pm 31 Aug 2014
I am getting (incorrect) -ve values other than -127. For example -83.25 when it should be around -15.
I am not at home at the moment; are you able to try the ONEWIRE command easily?
If so then I recommend initially displaying the temp in binary format and check this against the datasheet. Then I believe it will highlight that the error is located in the 'conversion' to a 'readable' format maybe??
DaveC166
Posted: 09:49pm 31 Aug 2014
I will give it a go. May take a day or two
DaveC166
Posted: 09:37am 01 Sep 2014
I have tried onewire commands instead of the DS18b20 function. the same result, temperature displayed correctly down to 0 deg. Bellow 0 deg getting between -125 and -127.0 displayed.
I have also tried displaying the temperature register high byte + low byte, this shows data reducing to 0 at 0 deg, but increasing to 401 below 0 deg, I thought the Ds18b20 would show 65528 for -0.5 deg .
Posted: 09:55am 01 Sep 2014
OK - I can confirm that Geoff (in his usual rapid way ) has fixed this -ve temperature 'issue'.
It will be included in 4.5D release along with a few other fixes.
Keep an eye out for news from Geoff as to when he is releasing 4.5D . . . .
WW
DaveC166
Posted: 12:02pm 01 Sep 2014
Ok I will hunt on EBAY for a PICKIT3
Posted: 12:28pm 01 Sep 2014
or use an FT232RL bridge and one resistor, with the software written by 'DaveS'.
rob :-)
DaveC166
Posted: 12:34pm 01 Sep 2014
HI Rob, can you provide any more info about the FT232RL bridge and software ?.
I managed to modify a onewire Function I found on this forum to work at negative temps
DaveC166
Posted: 01:31pm 01 Sep 2014
White wizard ,
this code seems to work
SUB STARTMEASURE (pinnbr)
onewire RESET pinnnbr
Onewire WRIte pinnnbr,2,5, &HCC, &H4E,&H00,&H00,&H7F
ONewire Write pinnnbr,8,2,&HCC,&H44
End SUB
FUNCTION GETREADING (pinnbr)
LOCal TH,TL
onewire write pinnbr, 1, 2, &HCC, &HBE
ONEwire read pinnbr, 2, 2, TL, TH
IF TH<16 Then GETREADING=((TH and &b111)*256 +TL)/16 '0 to 125 deg
if TH>=16 then
GETREADING=(256-TL)/16 'bellow 0 deg
GETREADING= -GETREADING
endif
end function
Posted: 08:03pm 01 Sep 2014
It's in the ZIP here from this page of a long thread.
You need an FT232R where you can get at the pins listed in the howto. Suitable boards on fleabay are about $3.
JohnSEdited by JohnS 2014-09-03
