Local Time 10:11 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : You Probably Already Knew This ...
hitsware
Posted: 03:44pm 08 Sep 2014
But new to me !
Really helps not to have to hassle
with their cable .
( I bought one, and if it would have
worked right, I'd be using it )
Edited by hitsware 2014-09-10
Posted: 08:21pm 08 Sep 2014
RevEd made no secret of the specs of their cable - I assume you are talking about AXE027 USB programming cable.
I have used a few USB cables to program PICAXE chips, including the common PL2303 one.
The key thing is that the USB adaptor has to be able to output a special signal that the system uses in programming over USB - native serial ports are no problems, but only some USB-Serial adaptors have the required signal. This is primarily why RevEd started selling their own cable, which was guaranteed to output the correct signals.
I have a couple of AXE027 cables, and I never had any issues getting them going.
I do seem to remember that you did have to install a RevEd USB driver for the cable - that might be your problem if you happen to be using Linux, which it seems you are by the pathname, as the RevEd driver will be a Windoze driver, not a Linux one.
