Local Time 09:23 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Wii Classic Controller
Oldbitcollector
Posted: 06:06am 09 Sep 2014
Before I start re-inventing the wheel, is there any chance that someone here has done Micromite compatible code for the Wii Classic Controller?
Jeff
My Propeller/Micromite mini-computer project.
Posted: 06:29am 09 Sep 2014
Jeff, take a look here for the Nunchuck.
However, regarding the Classic controller I personally have not seen anything.
WW
Oldbitcollector
Posted: 02:54pm 09 Sep 2014
I've got some spin code here for the Wii Classic controller, I'll look at starting to convert it next week.
Bill.b
Posted: 01:06am 10 Sep 2014
Hi Jeff
This is code for a WII classic controller in picaxe code.
It should not be to difficult to convert to micromite
I do not have a controller now so I can not attempt to convert and test.
[code]
' Program to read data form a Wii Classic Controller into a picaxe 28X2.
' Bill Brown Bill.b 29th July 2013
' I have tested the program with a 40X2 and it worked OK. The program does not work correctlly with M2 chips
' Some more work is required for M2s
' The Wii Receiver module required a 3.3volt supply.
' In my test unit i derived the 3.3v by connection two IN4001 diodes in series to the 5v supply giving approximatly 3.4v.
' 4k7 pullup reistors are unsed on the SCL and SDA - Connected to the +3.4v supply
' Data format for the 6 bytes of data from the Wii Classic Controller (WiiByte0 - 5)
'|Byte | Bit |
'| | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
'| 0 | RX<4:3> | LX<5:0> |
'| 1 | RX<2:1> | LY<5:0> |
'| 2 |RX<0> | LT<4:3> | RY<4:0> |
'| 3 | LT<2:0> | RY<4:0> |
'| 4 | BDR | BDD | BLT | B- | BH | B+ | BRT | 1 |
'| 5 | BZL | BB | BY | BA | BX | BZR | BDL | BDU |
'LX,LY are the left analogue stick, X and Y (0 - 63). RX and RY are the right analogue stick, X and Y (0 - 31).
'LT and RT are the left and right triggers (0 - 31). The left analogue stick has twice the precision of the other stick
' BD(L,R,U,D) are the D-Pad direction buttons. B(ZR,ZL,A,B,X,Y,+,H,-) are the discrete buttons.
'B(LT,RT) are the digital button click of the LT and RT. all Buttons are 0 when pressed.
#picaxe 28x2
setfreq m8
symbol WiiByte0 = b7 'Wii byte 0
symbol WiiByte1 = b8 'Wii byte 1
symbol WiiByte2 = b9 'Wii byte 2
symbol WiiByte3 = b10 'Wii byte 3
symbol WiiByte4 = b11 'Wii byte 4
symbol WiiByte5 = b12 'Wii byte 5
symbol WiiTemp0 = b13 'Wii Temperary storage byte
symbol WiiLeftX = b14 'Left stick X axis 0 - 63
symbol WiiLeftY = b15 'Left stick Y axis 0 - 63
symbol WiiRightX = b16 'Right stick X axis 0 - 31
symbol WiiRightY = b17 'Right stick Y axis 0 - 31
symbol WiiLeftT = b18 'Left trigger 0 - 31
symbol WiiRightT = b19 'Right trigger 0 - 31
i2cslave %010100100, i2cfast_16, i2cbyte 'I2C setup for Wii controller
hi2cout 0,($F0,$55) 'Wii Configuration bytes
pause 10
hi2cout 0,($FB,00) 'Wii Configuration bytes
pause 10
hi2cout 0, ($00) 'Wii Request data
'Main program start here
main:
pause 70
hi2cin 0,(WiiByte0,WiiByte1,WiiByte2,WiiByte3,WiiByte4,WiiByte5) 'Data from Wii Controller
'The following section arranges the data from the Wii bytes 0 - 4 into seperate bytes for used in the program
pause 50
WiiLeftX = WiiByte0 & %00111111 'Left stick X = Bits 0 - 5 of wiibyte0
WiiLeftY = WiiByte1 & %00111111 'Left stick Y = Bits 0 - 5 of wiibyte1
WiiRightX = WiiByte2 & %00011111 'Right stick X = Bits 0 - 4 of wiibyte2
WiiRightY = WiiByte2 & %10000000 'Move bit 7 of wiibyte2 to Right stick Y
WiiRightY = WiiRightY >> 2 'shift right 2 places
WiiTemp0 = WiiByte1 & %11000000 'move bits 6 & 7 of wiibyte1 to temp
WiiRightY = WiiRightY OR WiiTemp0 'Combine temp and right stick Y
WiiRightY = WiiRightY >> 2 'Shift right 2 places
WiiTemp0 = WiiByte0 & %11000000 'move bits 6 & 7 of wiibyte0 to temp
WiiRightY = WiiRightY >> 3 'Shift right 3 places. Right stick Y byte completed
WiiRightT = WiiByte3 & %00011111 'move Right Tigger bits 0 - 5 form wiibyte 3 to wiiRightT
WiiLeftT = WiiByte3 & %11100000 'move left trigger bits 5 - 7 form wiibyte 3 to wiiLeftT
WiiLeftT = WiiLeftT >> 3 'shift right 3 positions.
WiiTemp0 = WiiByte2 & %01100000 'Move Left trigger bits 3 & 4 to temp
WiiLeftT = WiiLeftT OR WiiTemp0 ' combine wiiLeftT and Temp
WiiLeftT = WiiLeftT >> 2 'Shift right 2 positions to complete wiiLeftT byte.
'debug
goto main
[/code]
Bill
Edited by Bill.b 2014-09-11
Oldbitcollector
Posted: 03:17pm 10 Sep 2014
If I understand correctly, the Classic Controller is I2C address &hA4 which the Micromite is unwilling to accept. Have I missed something or uncovered a bug?
Posted: 03:26pm 10 Sep 2014
Hi Jeff,
According to instructibles the address is &H52
Link
Oldbitcollector
Posted: 03:35pm 10 Sep 2014
Mick,
Just found that same link about the same time you posted it..
pressing on..
Oldbitcollector
Posted: 03:46pm 10 Sep 2014
Aha!
A word of caution.. Those china made clones do NOT work on the same as the branded Wii(R) classic controller. I just switched to an actual license product and started getting data.
Posted: 03:49pm 10 Sep 2014
Jeff,
It wouldnt be because of the selected controller channel would it?
Maybe your original remote (presumably controller 1) was set at &H52, and as you added new controllers they adopted another address? For User 2,3,4 etc?
Just theorising.
Oldbitcollector
Posted: 04:03pm 10 Sep 2014
Maybe. I'll have to do some more research after I get the real stick working.
BTW, how do I 'bit shift' on the Micromite? :)
Posted: 04:23pm 10 Sep 2014
  Oldbitcollector said  BTW, how do I 'bit shift' on the Micromite? :)
If x is your 'original' number then:
(x *2) AND &hFF [to shift left]
or
(x AND &hFE) / 2 [to shift right]
Use additional AND statement to extract bit required . . .
WW
Oldbitcollector
Posted: 04:52pm 10 Sep 2014
Stopping for the night.. Here's some working code that reads the Left Joystick control and most of the digital buttons.
[code]
I2C OPEN 10,100
i2caddr = &h52 'Nunchuck Address
Dim RDbuff(7)
I2C write i2caddr,0,2,&hf0,&h55
I2C write i2caddr,0,2,&hfb,&h0
I2C write i2caddr,0,1,&h0
Pause 100
readwii:
I2C read i2caddr,0,6,RDBuff(0)
Print Chr$(27)+"[f"; :Print Chr$(27)+"[2J";
up=0:down=0:right=0:left=0:home=0:select=0:start=0:btX=0:btY =0:btA=0:btB=0
LeftX = (RDBuff(0) And &b00111111)
LeftY = (RDBuff(1) And &b00111111)
RightX = (RDBuff(2) And &b00011111)
RightY = (RDBuff(2) And &b10000000)
If RDBuff(5) = 254 Then up=1
If RDBuff(4) = 191 Then down=1
If RDBuff(4) = 127 Then right=1
If RDBuff(5) = 253 Then left=1
If RDBuff(4) = 239 Then select=1
If RDBuff(4) = 247 Then home=1
If RDBuff(4) = 251 Then start=1
If RDbuff(5) = 247 Then BtX=1
If RDbuff(5) = 223 Then BtY=1
If RDbuff(5) = 239 Then BtA=1
If RDbuff(5) = 191 Then BtB=1
RightT = (RDBuff(3) And &b00011111)
LeftT = (RDBuff(3) And &b11100000)
Print "LX:";LeftX;
Print " LY:";LeftY;
'Print " RightX:";RightX
'Print " RightY:";RightY
Print " RT:";RightT;
Print " LT:";LeftT;
Print " Up:";up;
Print " Down:";down;
Print " Left:";left;
Print " Right:";right
Print "Select:";select;
Print " Home:";home;
Print " Start:";start;
Print " BX:";BtX;
Print " BY:";BtY;
Print " BA:";BtA;
Print " BB:";BtB
Pause 200
GoTo readwii
[/code]
Oldbitcollector
Posted: 04:55am 11 Sep 2014
I was looking over my digital IF statement checking code this morning and thinking that it might be a good idea to change that method to a binary 'and' method as the decimal numbers will change when multiple buttons are pressed.
Oldbitcollector
Posted: 05:19pm 12 Sep 2014
Here's an update which is friendly to simultaneous button presses..
[code]
'' CLASSIC.BAS V1.1 - By Jeff Ledger
'' Returns Left Controller & Digital Buttons from Wii Classic Controller.
'' Tested with licensed controller, may not work on clone controllers.
I2C OPEN 400,100
i2caddr = &h52 'Wii Classic Controller Address
Dim RDbuff(7)
Pause 100
Readwii:
rt=0:lt=0:up=0:down=0:right=0:left=0:home=0:select=0:start=0 :btX=0:btY=0:btA=0:btB=0
If (RDBuff(3) And &b00011111) = 31 Then rt=1
If (RDBuff(3) And &b11100000) = 224 Then lt=1
If Mid$(Bin$(RDBuff(5)),8,1) = "0" Then up = 1
If Mid$(Bin$(RDBuff(4)),2,1) = "0" Then down=1
If Len(Bin$(RDBuff(4))) = 7 Then right=1
If Mid$(Bin$(RDBuff(5)),7,1) = "0" Then left=1
If Mid$(Bin$(RDBuff(4)),4,1) = "0" Then select=1
If Mid$(Bin$(RDBuff(4)),5,1) = "0" Then home=1
If Mid$(Bin$(RDBuff(4)),6,1) = "0" Then start=1
If Mid$(Bin$(RDBuff(5)),5,1) = "0" Then BtX=1
If Mid$(Bin$(RDBuff(5)),3,1) = "0" Then BtY=1
If Mid$(Bin$(RDBuff(5)),2,1) = "0" Then BtB=1
If Mid$(Bin$(RDBuff(5)),4,1) = "0" Then BtA=1
Print "LX:";LeftX;
Print " LY:";LeftY;
Print " LT:";lt;
Print " RT:";rt;
Print " Up:";up;
Print " BX:";BtX;
Print " BY:";BtY;
Print " BA:";BtA;
Print " BB:";BtB
Pause 100
GoTo readwii
[/code]
