Local Time 09:23 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMite 170 chip - type?
Posted: 02:38pm 14 Sep 2014
Hi all.
Can you use the PIC32MX170F256B-I/ML as the basis of a 170 series MicroMite?
I think the "Normal" part number is PIC32MX170F256B-50I/SP.
The I/ML will be only a 40MHz part, but I don't care about the 50MHz speed for now.
Essentially - what is the difference between the I/ML part, and the I/SP part?
In my case, I am planning to get the QFN package version of the skinny-DIL, but just need to make sure that the QFN part number listed above, is still essentially the same chip as the skinny, albeit in the tiny QFN footpriint.
EDIT: I just found the answer to my own question on page 328 of the datasheet for the PIC32 in question - please ignore this post - perhaps delete it?Edited by Grogster 2014-09-16
