Local Time 08:35 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMite on an Arduino Shield
hitsware
Posted: 04:18pm 28 Sep 2014
What pins would go to what ?
Posted: 05:33pm 28 Sep 2014
Depends on what you want to do.
The sheild pinout can be found here among other places - scroll down a little.
You'll need the 3v3 and GND connections for power, but depending on what interface you need back to the Arduino, some of the other pins as well. A4 and A5 are the I2C bus.
MicroBlocks
Posted: 11:25pm 29 Sep 2014
You could use the CMM pinout as a guide.
Most critical will be the RX/TX (serial), SDA/SCL (i2c) and MISO/MOSI/SCK (spi).
then the PWM/Digital and analog pins to get as good a match as possible.
hitsware
Posted: 03:49am 30 Sep 2014
Actually for this project (USB Midi-Synth)
all I'll hook up is COM out and Tx Rx . It's
interesting though the power permutations.
(3.3 vs/and 5.0 Volt)
Depending on what's used for power and what's
supplied/needed by whatever 'shields' one uses.
hitsware
Posted: 02:24pm 30 Sep 2014
By the time I put in a USB-Serial gizmo there was
not enough room for the MicroMite to be comfortable,
so I used a PicAxe (also is OK with 5V that the synth needs)
Need the type cable with the circuit on the other end ...
(which I don't like for some reason ?)
Or a MicroMite with USB built in would be groovy
Edited by hitsware 2014-10-02
