Local Time 06:03 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CFunction Not working
micronut
Posted: 11:37am 01 Nov 2014
I have this code
Option Explicit
CPU 48
LCDLightOn
'C:\CFunctions\BAS\lcdlighton.bas
'lcdlighton 2014-11-01 17:24:29 CFuncGen Ver 1.0.16 by user=Brian
CFunction lcdlighton
00000000
3c02bf88 8c436114 34630001 ac436114 8c436138 34630001 ac436138 03e00008
00000000
End CFunction
'lcdlightoff 2014-11-01 17:24:29 CFuncGen Ver 1.0.16 by user=Brian
CFunction lcdlightoff
00000000
3c02bf88 8c436114 34630001 ac436114 8c436134 34630001 ac436134
03e00008 00000000
End CFunction
End
And I get
[4] LCDLightOn
Error: Unknown Command
Here is the C Code
* File: LCDBackLight.c
* Author: Brian
* Created on November 1, 2014, 2:21 PM
#include <plib.h>
#define BL_High *(volatile unsigned int *)0xbf886138 |= (1 << 0);
#define BL_Low *(volatile unsigned int *)0xbf886134 |= (1 << 0);
#define BL_Out *(volatile unsigned int *)0xbf886114 |= (1 << 0);
void lcdlighton(void){
BL_Out;
BL_High;
void lcdlightoff(void){
BL_Out;
BL_Low;
long long main() {}
What am I doing wrong?Edited by micronut 2014-11-02
G8JCF
Posted: 11:40am 01 Nov 2014
You must assign the result of your CFunction to a 64 bit variable, eg
Result%=lcdlighton
Result%
Your CFunction MUST return a 64 bit integer, eg long long lcdlighton(){....}
Peter
The only Konstant is Change
Posted: 12:59pm 01 Nov 2014
Also, it needs a dummy argument otherwise MMBasic will think that it is a variable:
Result% = lcdlighton(0)
G8JCF
Posted: 01:19pm 01 Nov 2014
To follow on from Geoff's comments, the CFunction code could look like
* Author: Brian
unsigned long long lcdlighton(){
BL_Out;
BL_High;
return 0;
unsigned long long lcdlightoff(){
BL_Out;
BL_Low;
return 0;
void main() {}
Then in MMBasic
OPTION EXPLICIT
CPU 48
DIM Result%
Result%=LCDLightOn(0)
END
'K:\Programming\PICProgramming\Micromite\UserSupport.X\dist\ default\production\lcdlighton.bas
'lcdlighton 2014-11-01 23:30:23 CFuncGen Ver 1.0.16 by user=Peter
CFUNCTION lcdlighton
00000000
27bdfff8 afbe0004 03a0f021 3c02bf88 34426114 3c03bf88 34636114 8c630000
34630001 ac430000 3c02bf88 34426138 3c03bf88 34636138 8c630000 34630001
ac430000 00001021 00001821 03c0e821 8fbe0004 27bd0008 03e00008 00000000
END CFUNCTION
'lcdlightoff 2014-11-01 23:30:23 CFuncGen Ver 1.0.16 by user=Peter
CFUNCTION lcdlightoff
00000000
34630001 ac430000 3c02bf88 34426134 3c03bf88 34636134 8c630000 34630001
END CFUNCTION
VERY IMPORTANT - NO SPACE allowed between LCDLightOn and (0), ie it MUST be LCDLightOn(0)
@Geoff, is that fixable in 4.6 ?
Give that a whirl, hopefully it will work !
PeterEdited by G8JCF 2014-11-02
