Local Time 01:21 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 7 Data Bits
edu001
Posted: 11:38am 25 Nov 2014
Hi
Is it possible to setup COM1 on the Micromite 44 pin as 7bit, no parity, 1 or 2 stop bits ?
I think the answer is no but I just wanted to check
Posted: 01:04pm 25 Nov 2014
Sorry, the answer is indeed no.
But, if your sender was using 7-bits and 2 stop bits you could receive it as 8-bits with one stop bit and ignore the high bit in the received character.
edu001
Posted: 08:15pm 25 Nov 2014
  Geoffg said   Sorry, the answer is indeed no.
Thanks for confirming that Geoff I thought that was the case, I read that you can get around the receive problem but I needed to transmit in that format
BobD
Posted: 08:40pm 25 Nov 2014
You may be able to do it like this. AND every character you send with &H80 (or &B10000000 if that floats your boat) so that the high order bit is always on and this is the same as a stop bit. You then have 7 bits of data and 2 stop bits.
Posted: 11:00pm 25 Nov 2014
If that fails, try ORing it.
(I'm unsure which way up the bits are!)
BobD
Posted: 01:14am 26 Nov 2014
  JohnS said   If that fails, try ORing it.
John, you have it right. I should have advised an OR.
Bob
