Local Time 23:42 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMLib update 14/12/2014
shoebuckle
Posted: 02:16pm 13 Dec 2014
Updates to MMLib include:
BATTERY3 - an updated version of Geoff Graham's BATTERY2 which has an additional option to write the final graph to a .BMP file with a heading and the system date.
CRUNCH v2.4 - an updated version which fixes a problem in CRUNCH.BAS, adds a testing switch /T to print debug messages and suppress removal of temporary files, and allows multiple keywords per line in KEYWORDS.BAS input files (makes it much easier to check these files when MMBasic is enhanced).(KEYWORDS.BAS was called RWSRTMRG.BAS in previous versions.)
The new library should be in Geoff's server shortly.
Cheers,
Hugh
shoebuckle
Posted: 02:22pm 13 Dec 2014
Is anybody interested in a version of CRUNCH that will support the MicroMite. At present CRUNCH output doesn't support it due to new rules for variables.
Cheers,
Hugh
paceman
Posted: 12:25am 14 Dec 2014
Hi Hugh - long time no see,
I'd think using the new libraries, which will need to incorporate those long variable names, would make ideal candidates for CRUNCH. So far all my programs are relatively short so I don't have the need but I'll bet there are others who will.
Greg
shoebuckle
Posted: 02:01pm 14 Dec 2014
  shoebuckle said  The new library should be in Geoff's server shortly.
Geoff says he will put it up on Wednesday.
Cheers,
Hugh
