Forum Index : Microcontroller and PC projects : ASCII Terminal MX150?
| vk2sja Newbie Joined: 07/06/2013 Location: AustraliaPosts: 26 |
Hi All, I just starting an ASCII Terminal build. But discover that the only 32 bit PIC micros that I have on hand are PIC32MX150F128B-50I/SP. Which "I think" I ordered in for building Micromite's (haven't got to that yet). Looking at the the ASCII Terminal documentation it calls for a PIC32MX250F128B-I/SP. Quick look at the data-sheets and one of the differences is USB OTG support (250 has 150 does not). Anyway can someone set me straight. Can I get away with my MX150F or (as I fear) must I order in some MX250F chips? Steve. |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10048 |
I think I read that someone else had used the 150's for the VT100 - you just can't have any USB side of things, but it does work on the 150's from what I remember reading. Others here will confirm that..... Smoke makes things work. When the smoke gets out, it stops! |
| cosmic frog Guru Joined: 09/02/2012 Location: United KingdomPosts: 311 |
Yes you can. I use the 150 and it works but without the USB. Dave. |
Thanks Dave and Grogster, Too close to Christmas now to get the MX250 so it's good to know that I can get away with the 150 over the break. I'm using it for a P112 CP/M machine via serial port. So won't miss the USB functionality in the short term. Merry Christmas All, Steve. |
Gday Steve, whereabouts in AUS are you? I am in Melbourne if you need a 250 quickly Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Hi Mick, Thanks for the offer but we're all good. I'll use the MX150 over the Break and truly I only need the TTL serial for this particular application. I'll order in some MX250's in the New Year and upgrade just so that I've got complete functionality when I do want to use the USB side of things. Nowra, New South. BTW. Cheers Steve. |
