Local Time 21:59 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Supervisory IC vs R/C on MCLR...
Posted: 02:09am 29 Dec 2014
Hi folks.
On page 14 of the Micromite manual, there is a diagram using a couple of resistors and a cap to delay the start-up of the PIC32.
Then there are the likes of the MCP120T-315 which can be connected to the MCLR pin to delay startup. The MCP part is only 45 cents, but if the R/C method works, is there any obvious benefit to using the more advanced MCP part?
Thanks for any comments.
EDIT: I am guessing that the MCP part would be more stable over time and temperature then an R/C network on MCLR, yes?Edited by Grogster 2014-12-30
MicroBlocks
Posted: 02:20am 29 Dec 2014
The added benefit is a controlled reset when brown outs occur. It monitors the voltage.
An r/c would not help in that case.
For embedded solutions that need to run unattended for very long periods of time a supervisory chip is a must as is a watchdog.
Posted: 02:55am 29 Dec 2014
Ahhhhhhhh - thanks, TZA - I thought there must be more to them then just startup delay. Useful information. I will proceed along the MCP path rather then R/C path.
