Local Time 21:57 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIC Programming voltage Vpp - alert
larny
Posted: 11:49am 29 Dec 2014
I recently discovered - by looking at some of the files in the MPLAB IDE Device folder (see Program Files (x86)\Microchip\MPLAB IDE\Device) - that the nominal programming voltage (Vpp) is not always 13 Volt. Some examples (taken from the respective .dev files) are shown below - note that the PIC 16F684 is 11 Volt nominal with a maximum of 12 Volt!
PIC16F84
vpp (range=12.000-14.000 dflt=13.000)
PIC16F88
vpp (range=12.500-13.500 dflt=13.000)
PIC12F675
vpp (range=12.750-13.250 dflt=13.000)
PIC16F684
vpp (range=10.000-12.000 dflt=11.000)
PIC16F917
All of the PIC programming hardware I have seen was designed to apply about 13 Volt. So I don’t know what would happen if one of these was used to programme a 16F684. But I don't intend to find out!
I recently purchased three of these PICs so I will modify one of my programmers so I can switch it between 11 and 13 Volt using a jumper shunt.
One of the programmers I constructed is the dSPIC/PIC Programmer published by Silicon Chip in their May 2008 issue. This one covers a wide range of PICs & it will be easy to modify. So I will do it in the new year and post the details in this forum.
Edit. I have just checked 2 more PICs & added them to the list above. Note that the 917 is also 11 Volt nominal.Edited by larny 2014-12-30
MOBI
Posted: 11:32am 30 Dec 2014
I have been using the SiliconChip PIC programmer for years now on all manner of chips. The programmer VPP is 13VDC. So far, I have not damaged any PICs.
I am making my own programmer and intend to make the VPP adjustable.
David M.
