Local Time 21:59 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Simple problem
nnvpaul
Posted: 05:23pm 30 Dec 2014
I have built a processor that cleans and processes waste motor oil for use as fuel for diesel engines. It works very well but it needs a controller. I have been building a program for it with a color maximite2. It has been time consuming because this is not something I am very familiar with. With a lot of trial and error I have been able to get the maximite to do everything necessary to control the unit except one small detail that I cannot figure out.
One of the tanks of the unit holds gasoline that is dispensed with a pump. It has been fairly easy to get the maximite to calculate the proper amount of time to operate the pump to dispense the desired amount of gasoline. The maximite also has to keep track of the gallons left in the tank which is also easy. The problem is that the maximite has to be shut down after the processor is finished. All of the variables are reset when the maximite is shut down and the gallons remaining are lost. Is there a way for the maximite to remember the gallons remaining? This seems like it should be simple but I am not getting it.
OA47
Posted: 05:34pm 30 Dec 2014
Gday Paul, you have the option of saving values to a file on the SD Card and read it back in to the program when it re-starts.
GM
Posted: 08:02pm 30 Dec 2014
Hi there - as Graeme says, you can save this to a file on the SD card.
You need to know your variable names, but I guess you do.
You could do this in a GOSUB or plain old sub like this:
SUB SAVE_SETTINGS:
Open "B:\SETTINGS.INI" for Outpuy as #1
Print #1,variable_name1$
print #1,variable_name2$
Close #1
End Sub
You can read the file back in as soon as you run your main code if you like, to restore the settings.
If you need me to elaborate, then let me know.
twofingers
Posted: 05:11am 31 Dec 2014
Hi nnvpaul,
or you can use a eeprom (on cheap RTC modules) for this.
Alternativly you can use a FRAM.
Regards Michael
The lone and ...
