Local Time 21:12 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VT100 ASCII Terminal Correction
Posted: 07:32pm 10 Jan 2015
While I was testing the VT100 ASCII Terminal I discovered an error in the specifications for the composite video output - the horizontal resolution was wrong. I don't know if many use that facility but just in case I thought that I should announce the find.
The correct specs are:
- Composite PAL : 288 x 218 pixels or 48 chars x 18 lines
- Composite NTSC: 264 x 180 pixels or 44 chars x 15 lines
My website (http://geoffg.net/terminal.html) has been updated as are the downloadable files.
cosmic frog
Posted: 02:27am 11 Jan 2015
Thanks Geoff.
