Forum Index : Microcontroller and PC projects : Latest MK II mmbasic
| atmega8 Guru Joined: 19/11/2013 Location: GermanyPosts: 738 |
Hi, in the last days there was a thread, where Geoff showed the latest MMBASIC ( Integer Problem, Display Option). I cannot find it again. Please give me a Link for Download. THX |
| Lou Senior Member Joined: 01/02/2014 Location: United StatesPosts: 229 |
atmega8, Is this the thread you were looking for ?? Here Lou Microcontrollers - the other white meat |
No, the latest Update IS only some days old... |
| bigfix Senior Member Joined: 20/02/2014 Location: AustriaPosts: 132 |
You find the thread here: http://www.thebackshed.com/forum/forum_posts.asp?TID=7329&PN =1&TPN=1 cheers Guenter |
This Iis not a working Link. No chance with IOS device;-((( Thank you. |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1773 |
Hallo Atmega, plz search for 2015-01-11_050958_Micromite_V4.6a.zip Regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Hi, this is exactly the Version i was looking for. Thank you very much. V4.6A |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10048 |
You only need to reflash to 4.6A if you need the composite video output on a VT100 setup to work. That's all that 4.6A fixes - everything else is the same. Don't flash this version for general purpose use, as it was specific to the one issue mentioned in that thread. IE: If you DON'T need the EDIT command etc to work correctly on a VT100 in Composite video output mode, then you don't need to worry about this alpha until a later final. Smoke makes things work. When the smoke gets out, it stops! |
Grogster, it fixes also a Bug when 2 Integers > 30 Bit are compared! |
