Forum Index : Microcontroller and PC projects : One-Wire - Missing librarys?
| MolsonB Regular Member Joined: 25/01/2015 Location: CanadaPosts: 48 |
Hi Everyone. I just started playing around with a ColorMax2, main goal is the read basic car type sensors. (temp, MAF, pressures, fuel levels, etc) There is a lot for me to learn and play around with, so I bought the one-wire DS1822 sensor to start. Upgraded the firmware to 4.5. In MMIDE, I can't get past the first line, OWReset 20 "unknown command". I thought the firmware loads all the library's? This is a total newbie question and I feel embarrassed. But we all have to start somewhere! -Matt MkII 44pin - v5.0 ColorMax 2 - v4.5 |
For long and complicated reasons I had to change the one wire commands from one word (OWReset) to two words (ONEWIRE RESET). Check page 63 of the manual for MMBasic V4.5. Geoff Geoff Graham - http://geoffg.net |
Ahh perfect. I was reading the Beginning guide. I just found the MMBasic V4.5 manual, will read that now. Thanks Geoff. MkII 44pin - v5.0 ColorMax 2 - v4.5 |
